3-Newcomer
June 28, 2023
want to set of session variable one parameter string value to null
Tring to set value of bsl as null but other properties values like temperature or owner should remain same in session.
this is the session input:
{"containerListFilters":{"location":[],"temperature":[{"array": [{"list_id": 1,"list_name": "RT"}]}],"owner":[], "bsl":[{"array": [{"list_id": 1,"list_name": "BSL 1"}]}]}}
output should be:
{"containerListFilters":{"location":[],"temperature":[{"array": [{"list_id": 1,"list_name": "RT"}]}],"owner":[], "bsl":[{"array": []}}
how can write the code for this?
TonyZhangAnswer
Support
July 7, 2023
Hi @PK_10315615
Don't know how setting a JSON element is related to session parameter but you can create a custom JS service in ThingWorx with a JSON input say called "input" and output as JSON
input.containerListFilters.bsl[0].array = [];
result = input;
TonyZhangCommunity ManagerAnswer
Support
July 7, 2023
Hi @PK_10315615
result = input;
