want to set of session variable one parameter string value to null
PK_10315615
3-Newcomer
Tring to set value of bsl as null but other properties values like temperature or owner should remain same in session.
this is the session input:
{"containerListFilters":{"location":[],"temperature":[{"array": [{"list_id": 1,"list_name": "RT"}]}],"owner":[], "bsl":[{"array": [{"list_id": 1,"list_name": "BSL 1"}]}]}}
output should be:
{"containerListFilters":{"location":[],"temperature":[{"array": [{"list_id": 1,"list_name": "RT"}]}],"owner":[], "bsl":[{"array": []}}
how can write the code for this?
Hi @PK_10315615
Don't know how setting a JSON element is related to session parameter but you can create a custom JS service in ThingWorx with a JSON input say called "input" and output as JSON
input.containerListFilters.bsl[0].array = [];
result = input;
Tony
1 REPLY 1
Hi @PK_10315615
result = input;
Tony
