Any OOTB Navigate services present to fetch CAD Structure ? and to fetch CADStructure with its quant
AP_10343008
Any OOTB Navigate services present to fetch CAD Structure ? and to fetch CADStructure with its quantity ??
The DocumentStructureAccessAppThing is designed to be used for the WTDocument use cases.
If you want to get the EPM Document (CAD Document) structure you need to use a different approach.
The connector that you can look for in the OOTB services is "ptc-windchill-OData-connector".
For Example the call "CAD_Get_Structure_Internal" can be used to get a CAD Structure from Windchill.
But as Andra wrote, sharing a bit more details about your environemnt and detailled use case would be helpful.
Depending on your Navigate version and your use case you would have to use a different approach.
The below example is using the CAD_Get_Structure_Internal service with an ID (EPM oid) and the $expand of "CADDocument,Components($expand=CADDocument,Components;$levels=3)". Which would get the epm structure of the assembly for 3 levels)
7 REPLIES 7
Thank you for your question.
I encourage you to bring more details and context to your initial inquiery to increase your chances to receive meaningful help from other Community members.
Andra
AP_10343008
(To:achirila)
I want to know the inputs of this OOTB Navigate Service
Thing:DocumentStructureAccessAppThing
Service:GetStructure
In which thing, you using CAD_Get_Structure_Internal service ?? I couldnt find this service in ptc-windchill-OData-connector.. What thingtemplate it is used ?
the connector that is used by Navigate to connect to Windchill is called:
This connector thing has the service. But depending on your environment you might need extra/different configuration steps.
Which version of Navigate are you using?
Thingworx navigate 9.1 version
For Navigate 9.1 you would need to add a new Route at the ptc-windchill-OData-connector
You would have to add the GetStructure Service from the CADDocumentMgmt domain.
But this also depends on the version of Windchill REST Services that are installed in your Windchill system.
