All,
Using Navigate, can I search a particular word or phrase inside a PDF stored in Windchill PLM.
Can I utilize the advance search capabilities of Windchill within Navigate, e.g. listing the search results from Windchill in the Navigate window?
TIA
Yes you can use saved search from Windchill. See link : http://support.ptc.com/help/navigate/r8.5/en/#page/ThingWorx_Navigate%2FNav_PLMTailorBestPractices.html%23
You just need to create a global saved search in Windchill with dummy keyword.
And use it in "Edit Collection" of Navigate.
This way the search keyword of Navigate will be used as search keyword in Windchill and returns appropriate results.
Kind regards.
Kind regards.
Kind regards.
Kind regards.
Hello ajay252508,
Can you mark post as solution provided if you don't have more questions.
Kind regards.
