Can we use single DB instance that can be used for multiple Thingworx instances?
Keerthi
Hi @SCOTT2.0.
If you are running multiple active ThingWorx instances, each will require its own db instance. However, multiple db's can be created under a single RDBMS.
--Sharon
Hi @SCOTT2.0.
--Sharon
