I want to ok install Thingworx navigate, Thingworx foundation and Thingworx flow and also need to setup sso in azure for Thingworx. Anybody is having the documents or videos step by step guides even though creation of keystore files. I went through ptc help centers it totally confusing ,not sequential, skipping some steps and mis leading to lot of confusion. As m doing this first time so please anybody having these documents please provide.
Thank you in advance
"Install and Configure ThingWorx Navigate": https://www.ptc.com/en/success-paths/thingworx-navigate/develop/install-configure-thingworx-navigate
Hi Vladimir,,
Thanks for your reply, I have already gone through this link! again, same it will provide the high-level steps and didn't clearly mention. As those who will do this first time definitely stuck.
Any other document manually created or updated not by PTC.
KSM
Have you also visited "Reference Documents" page on eSupport:
Hi Vladimir,
I gone through the link which you have provided, it's the same but only difference is that consolidated in pdf. I think there is no other documents from PTC which can spoon feed.
KSM
