hello everybody, I needs to do a search in thingworx navigate starting from a property saved in a things of thingworx as search field.
I thinks I have to use thingworx flow but i do not know how to do it.
thanks for any response
Fabio
You can do searches against Windchill with REST calls.
With swagger Example : https://www.ptc.com/en/support/article/CS314207
or with ODATA : https://<YOUR_WINDCHILL_SERVER>/Windchill/netmarkets/html/wrs/doc.html
Flow is not really needed.
Kind regards.
Kind regards.
Hi , unfortunately I don't have access to the link.
I was thinking of flow as the parameter comes to me from Vuforia studio that searches windchill using thingworx flow
thanks for the reply is very valuable
Fabio
