I have installed Thingworx 9.0 instance and running an application. I have installed it manually without using installer.
Based on requirements, I have to install Thingworx Navigate 9.0. when I'm trying to install navigate it's again asking me to install Thingworx foundation using installer. Is there a way to install Navigate without removing existing instance. The server is having only one drive so i can't use two instances also.
Any suggestions on this?>
-thanks,
Abhiram
Hello @abhiramk
As far as I know, Navigate has moved to the link below, where you can ask your questions
https://community.ptc.com/t5/Thingworx-Navigate/bd-p/thingworxnavigate
BR,
Max
Hi Abhiram,
Starting ThingWorx Navigate 9.0, ThingWorx Foundation 9.0 must be installed using the installer before installing
ThingWorx Navigate. Please refer to the Prerequisites section of ThingWorx Navigate 9.0 Installation guide
There is currently no bundle of extension files available for ThingWorx Navigate 9.0 to use with a manual install attempt.
Arshad
