I am currently using a Dynamic Menu which will generate items based off the logged in user options. I would like to send parameters to a contained mashup based on which menu item they select. How can we do this.
Hi @farmerj1.
Could you provide more information about your use case? What parameters are you sending to the contained mashup?
--Sharon
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
