How to create a epicycloidal sketch in CREO 2.0?
SOLVED
Highlighted
Level 1
I've seen tutorials for creating cycloidal or epicycloidal using SolidWorks & Blender. Can anyone tell me where to find a tutorial or instructions on how to do this with CREO 2.0?
1 ACCEPTED SOLUTION
Re: How to create a epicycloidal sketch in CREO 2.0?
I'd use the curve by equation feature.  Then you can trace the curve entities in your sketch...
Equations for Curves (and more)
Or this one: http://mathworld.wolfram.com/Epicycloid.html
Here's an example in Creo 2.0:
2 REPLIES 2
You'll probably also want to construct one lobe and pattern if you're looking to create a solid. You may also need to adjust the angle used in the equations.
