how to publish experience on spatial target along with thingmark
InfinityX
how to publish an experince on spatial target in vuforia studio along with thingmark
i want to use thingmark for initial tracking purpose but after that i want to use the spatial target for putting model on floor
InfinityX
(To:jirvin-2)
i got the answer
we just need  Spatial target as a launch point (target) and no need to use Thingmark Target instead we need to mention just thingmark ID for an identifier by configuring the project’s Experiences section
6 REPLIES 6
To publish an experience with a spatial target and ThingMark, you can use a ThingMark as an identifier for the experience and a spatial target for the launch point. Identifiers are used to determine which experience to load in the Vuforia View app while targets are used to place the augmented content in your 3D space.
Use a ThingMark as an identifier by configuring the project’s Experiences section:
  1. Set the ThingMark Association field to ThingMarks
  2. Enter the appropriate ThingMark code in the ThingMark field
Use a Spatial target as a launch point (target) by:
  1. Drag and drop a Spatial Target widget into the 3D canvas
  2. Configure properties, events, services as needed
-Jill
InfinityX
(To:jirvin-2)
when i want use the both target this is what the error comes out
Only one target is permitted in a view. Could you explain the need to have a ThingMark and a Spatial target for your use case?
-Jill
InfinityX
(To:jirvin-2)
i got the answer
Great!
InfinityX
(To:jirvin-2)
Thanks for your valuable information
