Hello, the flashlight function on Samsung S10 does not work anymore!
Also the flashlight function on Samsung S20 does not work.
Looking forward to your thoughts,
Pontus
This is a known issue with ARCore devices. Until a fix from Google is available, any device on this list will not be able to use the flashlight within Chalk: https://developers.google.com/ar/discover/supported-devices
