Mar 26, 2020 4:08 PM UTC
Re: Initiate or receive from a PC
  1. Is there no other way to start a session from Chalk Desktop other than sending an email link or a Connect Code. Why are there no contacts in Chalk Desktop?
  2. How to start a session from Chalk app on mobile inviting someone using a desktop? If a lab engineer starts a session it would be more convenient for the office engineers to use Chalk Desktop. As it is now I get the call from a lab engineer in my mobile.
Magnus
    Mar 26, 2020 8:42 PM UTC
    Hi @magnus.salomons
    Right now Desktop only supports Chalk calls using Connect Codes. Within the mobile Chalk app you can select 'Start a Session'. This will open up a new session screen with a Connect Code displayed. The lab engineer can then use the 'Share' feature below the Connect Code to send the office engineer the Connect Code via whatever method they like (email, text, etc). Once the office engineer has the connect code they can enter it into the Desktop app using the 'Join Session' option to connect to the remote user's session.
    Mar 27, 2020 12:27 PM UTC
    Thank you @tmccombie , that worked ok.
    We tried a session today but unfortunately got the message below. Is it not possible to use sketches on the screen with Chalk Desktop? Both users are hosts.
    Mar 27, 2020 3:04 PM UTC
    Hi @magnus.salomons
    Annotations are possible on Chalk for Desktop. Did the 'local user' (the one who was sharing their screen) follow the initial instructions displayed that allows Chalk to map the environment? It looks like this:
    Once the local user successfully does that, you should be able to add Chalk marks. I just tested locally and was able to add Chalk marks using Desktop.
