Samsumg X Cover Pro Support
SF_9967276
2-Explorer
Is Vuforia Chalk support by Samsung X Cover Pro?
Sergio
yue
11-Garnet
11-Garnet
(To:SF_9967276)
Hello @SF_9967276
The following is quoted from Vuforia Chalk Help.
Android 8.0 or Later and only 64-bit Android versions are supported.
Most AR Core devices should work with Vuforia Chalk. * Samsumg X Cover Pro is listed in AR Core deives
Not all ARCore devices may work. To see if your device is now compatible with Chalk, you may need to override the Session Mode setting in your Chalk settings by changing it from Audio-Vidio Only to Audio-Vidio With Live Annotations.
The following devices have been tested and verified as compatible with Chalk:
Google Pixel 1, Google Pixel 2, Google Pixel 3, Samsung Galaxy S7, Samsung Galaxy S7 Edge, Samsung Galaxy S8/S8+, Samsung Galaxy S9/S9+, Samsung Galaxy Note 8, Samsung Galaxy Note 9, Samsung Galaxy A8/A8+, Samsung Galaxy S10, Samsung Galaxy S10e, Samsung Galaxy S10+, Samsung Galaxy Note 10 (including 5G models), Samsung Galaxy Note 10+ (including 5G and Note 10 Lite models), Samsung Galaxy S20 Ultra (including 5G models), Samsung Galaxy S20 (including 5G models), Samsung Galaxy S20+ (including 5G models), Samsung Galaxy A40, Samsung Galaxy A50, Samsung Galaxy A70, Samsung Tab S3, Samsung Galaxy Tab S4, and more coming soon!
