Hi, I am looking for an answer on two questions that relate to Chalk video performance and network connectivity:
Thank you,
Mike
Thanks, Mike, for those great questions.
Regarding the first topic:
Correct, though the initial connection is done via the server, all video, audio and images are delivered using a peer-to-peer delivery model (no intermediary server for transmission).
Regarding your second topic:
Our video streams are adaptive where we will adapt video resolution and frame rate to maintain a real-time view of the local user’s camera feed.
Examples:
Below 500 Kbps (when the Remote Expert experiences choppy video where details cannot be made out) – we encourage the Remote Expert to enable our “low bandwidth mode”.
Then Vuforia Chalk will switch from video stream to an image stream delivered over HTTPS. There will be a trade-off between real-time and quality. So the low bandwidth mode ensures a usable and clear image and still allows annotations.
So the recommendation would be to have a bandwidth higher than 500 Kbps, but Vuforia Chalk is still able to support situation with low bandwidth connections. Exactly this is one of the unique strengths of Vuforia Chalk.
Best regards
Rayed
