Query regarding VEC editor procedure
GV_10024445
3-Newcomer
Posting this query regarding VEC editor procedure. For example if we create a procedure A and B with different steps in each procedure, wish to merge these two procedures as one. Is there anyways to achieve this in editor? Could you help on this please?
1 REPLY 1
The ability to build a more complex procedure is something that is in the roadmap. The current release does not support merging of procedures. You can create   a new procedure and manually copy text from one to the other and use media assets used in other procedures.
