Posting this query regarding VEC editor procedure. For example if we create a procedure A and B with different steps in each procedure, wish to merge these two procedures as one. Is there anyways to achieve this in editor? Could you help on this please?
The ability to build a more complex procedure is something that is in the roadmap. The current release does not support merging of procedures. You can create a new procedure and manually copy text from one to the other and use media assets used in other procedures.
