Hello Community,
I would like humbly ask that i am calling an API to get all the insights but the title, firstName, lastName and email fields are having stars when it returns the result. I am using an access token which i get using service principal and then use that token to hit an api and in return i get these below results. any idea ? how can i get these fields values also because i want these fields also thank you
"sessionId": "2d66ed8b-6c47-412b-80c7-32c9667787f6",
"procedure": {
"id": "48c69db0-bb83-11ee-8f1a-bff74c53c6d0",
"title": "****",
"versionId": "e93ea4d66eabbdf2c4974e5c",
"versionName": "3.0",
"startTime": "2024-12-04T17:25:44.077Z",
"latestEventTimestamp": "2024-12-04T17:26:36.305Z",
"endTime": "2024-12-04T17:26:36.305Z",
"status": "complete",
"progress": "completed",
"feedback": "na",
"requiresSerialNumber": false
"user": {
"id": "729ef656-0e14-42cb-9a0e-33244043cec4",
"first_name": "****",
"last_name": "****",
"email": "****",
"role": "****"
Hi.
This is not dependant from your API call. There is a setting to enable/disable user information to be hidden in API call. The documentation for this is available here: https://support.ptc.com/help/vuforia/editor/en/#page/vuforia_editor%2Fsettings_prod_updates_disable_user_info_api.html%23
Hi.
Thank you for your reply but do you know how can i enable these settings? any idea?
i found in setting this to enable or disable such information... thank you for your reply
