I am currently using the method :
$scope.app.fn.loadResourceScript("app/resources/Uploaded/btnMult.js"); //On community was told that is a method to import modules from Uploaded.
then ,to connect the modulo function to the $scope i did:
$scope.mult=function(x){
mult(x)
the file "btnMult.js" ,contains :
function mult(x){
return x*x
There is nothing more on the file, but when i run the file ,i got an error ,telling "mult is not defined"
Can somebody give me a help? I did every option that are related on importing but nothing works...
Hi @RB_10104920 ,
I never used the mentioned api but I loaded scripts fromt the Upload project folder (or subfolders ) using following scripts:
//---------------Loading the API-----------------------
$scope.asyncLoadScript = function (fname) {
return new Promise((resolve, reject) => {
if(fname) { var head = document.head || document.getElementsByTagName('head')[0],
script = document.createElement('script');
script.async = true; script.onload = resolve;
script.onerror = reject; script.type = 'text/javascript';
script.src=fname; head.appendChild(script); } });}
var mathe =undefined;
$scope.mathModuleLoad = function() {
console.log("mathModuleLoad started");
$scope.asyncLoadScript("app/resources/Uploaded/MyMathFunc.js").then(
function() { console.log("myMathFunc was loaded successfully") ;TESTLOAD();},
function() { console.log("error for when loading myMathFunc.js module");} );
$scope.mathModuleLoad(); //LOAD dhere the myMathFunc.js for
The example code above loaded e.g. my math js module
Here another version which will load both js or css files from project folder:
$scope.loadjscssfile= function(filename, filetype){
if (filetype=="js"){ //if filename is a external JavaScript file
var fileref=document.createElement('script')
fileref.setAttribute("type","text/javascript")
fileref.setAttribute("src", filename)
else if (filetype=="css"){ //if filename is an external CSS file
var fileref=document.createElement("link")
fileref.setAttribute("rel", "stylesheet")
fileref.setAttribute("type", "text/css")
fileref.setAttribute("href", filename)
if (typeof fileref!="undefined")
document.getElementsByTagName("head")[0].appendChild(fileref)
//loadjscssfile("app/resources/Uploaded/myscript.js", "js") //dynamically load and add this .js file
//$scope.loadjscssfile("app/resources/Uploaded/style1.css", "css")
Hi @RB_10104920 ,
Ty Roland =D worked
Superb!
Very helpful 😀
