Adding more than one sequence to a model
DFFHTW
8-Gravel
I want to have several buttons in my 2d overlay and each of them should move a different axis of an industrial robot in Thingworx View.
Do I have to add a new model for each sequence step? (there's only one sequence to choose in the model properties). I don't want to go through the steps in a particular order.
I want button 1 to start sequence 1 and button 2 to start sequence 2 and so on...
How can I do that?
DF
Same issue for me also,currently i am adding individual model and playing the sequences individually.
I tried various sequence adding method but failed.
help me out.
Thanks in advance
Naveen,
I recommend you use the search function becaues "several" sequences was already discussed many times and is of course possible.
For Digitale Fabrik,
There are many different possibilities. But of course you won't need several models to have several sequences. Same applies here - the solution has been described already (just one way).
Can't use more than one sequence animation in a single experience in ThingWorx studio.
Martin
