Hi everyone,
I would like to call a function on changed value event. How can I do this?
The value to be monitored is in a label, it is used to indicate the step of my animation. The property text of label is binded to CurrentStep of my 3D Model which contains animation sequences.
Maxime.
Hello @MaximeDid ,
one possible option to define a change value event and to call an action when a widget property will chang , is to use the $watch angular construct / defintion in javascript e.g. in the Home.js -> some code like this:
$scope.$watch("view.wdg['label-1']['text']",
function (newValue, oldValue, scope) {
console.log("Old Value -befor it was changed =" + oldValue);
//! it could be undefined first time called
console.log("new Value -after it was changed =" + newValue);
//prints the current $scope (copy) object passed to the $watch construct
// pay attention it has no $ !
console.warn(scope);// the scope variable passed to the function
// this is the same as $scope but has not the $-char
Hello @MaximeDid ,
