Call function on view is loaded
drichter
I will call a service automatically when a view is loaded. I try this via window.onload or document.onload but this will not work. How can I realized this?
Yes, I'm sure, I use it all the time. But you have to define the function first before assigning it as a callback. So try this instead:
$scope.init = function(){
  console.log("bla");
angular.element(document).ready($scope.init);
5 REPLIES 5
You can do this by adding something like this to each View's JS pane:
angular.element(document).ready($scope.storeInitialState);
Replace "$scope.storeInitialState" with the name of your function, and it should fire when the view is done loading.
drichter
(To:ClayHelberg)
I add this to my code:
  console.log("bla");
and I get this in my console logs:
TypeError: a is not a function
Are your sure I can use angular stuff in TWX Studio?
drichter
try this .....
angular.element(document).ready(function () {
$scope.init();
  console.log("bla");
I hope to be proved helpful.
bye
Giuseppe
  console.log("bla");
drichter
(To:ClayHelberg)
Thx that works 🙂
