I appreciate that you added a gaze cursor in the last update. Is there a way to adapt it's depth value to the surface of the object which the user is gazing on (like known from common AR and VR applications)? Not adapting the depth value correctly can cause cybersickness and is stressful for the eyes.
If not, is there a possibility to don't show the gaze cursor?
Lara
