Does Select Widget have a different PopupListBox shape for different devices?
wxywxy1
11-Garnet
Can't I see the same shape on other devices as i see in vuforia-studio?
and
can i hide label?
Hi @wxywxy1 ,
to the first part: "Can't I see the same shape on other devices as i see in vuforia-studio?"
Is this a question or statement /problem description. If yes, then please provide a picture what you consider as problem where you mark the difference
to the second part/question:
"can i hide label?"
label from what / widget label or the select widget simple reset the label property:
$scope.view.wdg['select-1']['label'] ="Label value";
