Hide Buttons while Step/Sequence is playing
JD_9967989
Hi, I'm looking for a way to hide buttons while a step/sequence is playing. I know that there is some kind of check I could add in Creo Illustrate but unfortunately I don't have the original files so need another way.
I have 10 buttons with each triggering a seperate animation & audio file and I'd like to hide those buttons while the animations are playing. Looking forward to your code!
Add to Model Events
Play Started : playStart()
Play Stopped : playStop()
Disable Buttons
$scope.playStart = function(){
  $scope.view.wdg['button-1'].disabled = true;
  $scope.view.wdg['button-10'].disabled = true;
$scope.playStop = function(){
  $scope.view.wdg['button-1'].disabled = false;
  $scope.view.wdg['button-10'].disabled = false;
Or change Visibility
  $scope.view.wdg['button-1'].visible = true;
  $scope.view.wdg['button-10'].visible= true;
  $scope.view.wdg['button-1'].visible = false;
  $scope.view.wdg['button-10'].visible = false;
Add to Model Events
Disable Buttons
