I have a service in ThingWorx with some inputs inside it.
I want to set those inputs from Vuforia Studio.
Can anyone help me out asap please?
Thanks in advance.
Aditya Gupta
The easiest way is probably to bind an application parameter to the service parameter. Once you have added the service to your External Data, you'll see a Parameters entry under it, open that and you can use drag and drop bindings to send data to the service.
