Increasing the opacity of model using JS
  • March 29, 2020
  • 1137 views
Initially i have set the opacity of model to be 0 and want it to gradually increase from 0 to 0.8 when a button is pressed using javascript. I tried do-while loop but it didn't work for me.
Any help would be appreciated.
Hi @vivekse ,
I think this is working fine in generally.
I do not know  what is your code but , one possible reason is if you have set a sequence , which could override the modelItem setting also the opacity property. Therefore you can un set the sequence property  of the modelwidget e.g :
$rootScope.$on('modelLoaded', function()
//================= unset the sequence property of the model widget
 $scope.setWidgetProp('model-1', 'sequence', "");
Here an example where I tested it and it worked fine:
In the sample project here I have 2 functions: FadeOut and FadeIn . The FadeOut function will "FadeOut" the opacity of particular widget for a  time / time inerval / from current value  to 0 and the function FadeIn will increase the opacity In a time inerval from 0 to a specific value:
$scope.fadeOut = function(widget, time, interval) {
 let w = (widget.opacity !== undefined ? widget : $scope.view.wdg[widget]); //wiget name or widget it self
 if (time <= 0 || interval <= 0 || w.opacity === undefined) { throw "Cannot fade this widget"; }
 let steps = Math.floor(time / interval);
 let opDelta = w.opacity / steps;
 return $interval(() => w.opacity = (opDelta < w.opacity) ? (w.opacity - opDelta) : 0, interval, steps);
$scope.fadeIn = function(widget, targetOpacity,time, interval) {
 let opDelta = targetOpacity / steps;
 return $interval(() => w.opacity = (targetOpacity > w.opacity) ? (w.opacity + opDelta) : targetOpacity, interval, steps);
//=============== Button function
$scope.testFadeOut= function()
$timeout( ()=>{$scope.fadeOut($scope.view.wdg['modelItem-1'],2000,200) } ,500)
$timeout( ()=>{$scope.fadeOut($scope.view.wdg['modelItem-2'],4000,200) } ,1500)
$timeout( ()=>{$scope.fadeOut($scope.view.wdg['modelItem-3'],6000,200) } ,2500)
$timeout( ()=>{$scope.fadeOut($scope.view.wdg['model-1'] ,5000,200) } ,3500)
//====== second button function
$scope.testFadeIn= function()
 $timeout( ()=>{$scope.fadeIn($scope.view.wdg['modelItem-1'],0.8,2000,200) } ,500)
 $timeout( ()=>{$scope.fadeIn($scope.view.wdg['modelItem-2'],0.9,4000,200) } ,1500)
 $timeout( ()=>{$scope.fadeIn($scope.view.wdg['modelItem-3'],1.0,6000,200) } ,2500)
 $timeout( ()=>{$scope.fadeIn($scope.view.wdg['model-1'] ,1.0,5000,200) } ,3500)
The sample mobile Studio  project was uploaded
