I cannot bind a click event of a label to the visibility of another label (eyewear project).
Same with 3d images - why?
Is there a way to do this with json? If yes, can someone help me with the syntax? I'm not very familiar with coding.
Version: 8.2.2.3099
DF
Here is my suggestion:
$scope.OnLabelClick = function() {
$scope.view.wdg['3DLabel-2']['visible'] = true;
OnLabelClick();
Good luck,
Ricardo
thank you very much! This helped a lot.
Is there a list anywhere with all available commands for the home.js like the $scope.view.wdg?
In specific, whats the command for starting the sequence of a model?
DF
