I want to put a button on my Home screen that will launch one of the other views. Can this be done?
Replace Unit button would launch the Replace AC Unit View
Hi Sandra,
Yes, it is possible. Please follow the below instructions for the navigation:
This will bind the button's click event to the view's navigation.
Hope this helps!
Hi Sandra,
Hope this helps!
Yamini,
This worked perfectly!
Thank you for your quick response!!!!!
Sandra
Glad that I could help!
