I have multiple scanned areas, which I will be separating in different views. The problem here, is that I have some objects in those areas, that might be moved somewhere else like chairs, keyboards, etc. Will there be complications with the scanned areas?
When is the optimal time to split the scanned areas into separate experiences or views?
usually it is not a problem if some objects are moved as long as the overall difference is not too much. I guess you just have to test the targets if they are robust enough for your use case.
What do you mean by 'optimal time'? You should offer the user to switch to another view when they are about to leave the current scanned area.
