Node.js Rest API example- how to display data from the local network in Vuforia Studio project?
  • November 14, 2018
  • 0 replies
  • 3897 views
Here we have the same start state as described in “How to read sensors via Rest API call in and display it Vuforia Studio experience project?”… but with one significant difference. The sensors URLs are not visible for the Thingworx service. The problem is that the sensors values should be requested via Rest API calls in a local intranet. This means that the end devices are connected to a local router but they  have also internet access. So, they could see the Experience Server and could download the experience. The sensor URL and rest API call should be some thing like:
var url="http://172.16.40.43.5900/api/v0/dev_id=6&size_id=123";
So, it means the IP address of the device, where the value should be requested via Rest API call is not visible from outside the local wlan and the Rest API call could be done only inside the local network.
So here e.g. we can use a node.js program which will request the sensors and will send the values to thingworks. So the main loop is an interval callback function “requestFunction” which is called here in example every 5 seconds. It will read the sensors data via Rest API fetch call (here from a test server)
var http = require('http')
var https = require('https')
const fetch = require('node-fetch')
var request = require("request")
var userId = 1 //could be from 1 to 10
var todosId = 1 //could be 1 -200
function requestFunction() {
 userId = Math.floor((Math.random() * 10) + 1)
 todosId = Math.floor((Math.random() * 200) + 1)
 fetch('http://127.0.0.1:8081/userId/' + userId)
 .then(response => response.json())
 .then(json => {
 console.log(JSON.stringify(json))
 setPropValue("profession", json["profession"])
 setPropValue("userName", json["name"])
 setPropValue("userId", json["id"])
 setPropValue("userPassword", json["password"])
 fetch('http://127.0.0.1:8081/api/todos?id=' + todosId)
 .then(json => {
 setPropValue("message", json["title"])
setInterval(requestFunction, 5000) //every 5 sec
The syntax of the Rest API  call where we will set/ change the value of the thing property we can  check from the  REST API Reference Guide
https://developer.thingworx.com/en/resources/guides/rest-api-how-guide
Property values access:
https://developer.thingworx.com/en/resources/guides/rest-api-how-guide/property-values-rest-api-how
 When we review the code above we can see that there is function “setPropValue” which should set a value to a particular property. Here the twx server:port is mxxxxx7o.studio-trial.thingworx.io:8443. The Thingname is fixed “REST_API_EDGE”
function setPropValue(propName, propValue) {
 var options = {
 method: 'PUT',
 url: 'https://mxxxxx7o.studio-trial.thingworx.io:8443/Thingworx/Things/REST_API_EDGE/Properties/PROPNAME',
 headers: {
 // use here the user appKey who created the Thing /here REST_API_EDGE
 appKey: 'fxxx7x4a-19x4-4xx3-bxxxa-9978a8xxxx17x', //appkey for the user
 'Content-Type': 'application/json'
 body: { PROPNAME: 'XXXXXXX' },
 json: true
 //this will make a string from the option json and will replace the
 // place holder “PROPNAME” by function argument propName
 var str_temp = JSON.stringify(options).replace(/PROPNAME/g, propName)
 //this will replace place placeholder XXXXXXX by function argument propVaule
 // and will convert the string back to json
 options = JSON.parse(str_temp.replace(/XXXXXXX/g, propValue))
 console.log("option in setPropValue:")
 console.warn(options)
 request(options, function(error, response, body) {
 //print the return code – success is 200
 console.log("response.statusCode=" + response.statusCode)
 if (error) {
 console.log("error in request");
 throw new Error(error);
 console.log("response")
Mostly the generated code should be postprocessed. When we start the script we can verify that the property values will change every 5 seconds.
111118.jpgThebest way now /also the supported way is to get data in Vuforia studio is via the External DATA panel
Afterwards  we can test in the Preview and later on the end device:
