I want to make an interactive repair tutorial using Vuforia. In order to play the different video sequences created in Illustrate one after the other, I need to add selection buttons to play the corresponding video. I would like to know how to link the videos one by one. Is there a code for this?
Ich möchte eine interaktive Reparatur Anleitung mittels Vuforia machen. Um die verschiedenen Videosequenzen, die in Illustrate erstellt wurden, der Reihe nach abspielen zu können, müssen Auswahlbuttons eingefügt werden die das dementsprechende Video abspielen lassen. Ich würde gerne wissen wie ich die Videos einzeln aneinander verknüpfen kann. Gibt es dafür einen Code?
Translated with DeepL Translate.com
Translated by Corina Ionescu, Feb 18th, 2022
I'm not sure if I clearly understand the question and whether you want to switch and activate animations/sequences created and stored in PVZ exported from Creo Illustrate or just show different video files, created with Creo Illustrate.
Nevertheless, in any case, you just need to dynamically change a corresponding property of the corresponding widget (the 'sequence' property of the 3Dmodel widget or 'source' for Video / 3D video widget).
This has been discussed earlier - check these links for samples / details:
Also, I highly recommend going through the excellent tutorials and examples in Help Center:
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2Fjs_basics.html%23
