error: [twx-studio:basic] Failed to authenticate experience server
I am working on thingworx studio and unable to connect to experience url. I tried to visit to Thingworx experience url like -> https://********.**.vuforia.io:8443/Thingworx/Composer/index.html and it is working fine, but its giving error in validation
Thingworx studio->configuration ->info->experience service when i am copping same experience server URL like-> https://********.**.vuforia.io:8443 as well as unable to publish the same,
can any one provide a demo or any documentation on setting for thingworx studio and experiance url.
Thank you
In your case, the Experience Service url under studio configuration shouldn't include 8443. The ES url should be "https://*******.**.vuforia.io"
Hi pravin pradhan, 8443 is port number for ThingWorx. So, as giri mentioned; try validating Experience Service url under studio configuration without port 8443
