Unable to change the text area background color
RK_9880418
I tried to create a card. So I just placed the text area widget. I want to reduce the opacity, whenever I tried to change the rgba for text area widget, I doesn't change. It remains white background. Can you suggest me that how to change the same @SC @it
you can try to use some class definitions and set them to the class property.
So for  example in the App.css // Studio >>> STYLE >> Application
.my_transp_area {
   background: transparent;
.textarea1 {
  background-color:transparent;
  line-height:30px;
  font-weight:bold;
  color:black;
  opacity:0.4 ;
and then set this to the class property (for Card and textarea widgets)
So this will make some effects of transparent apperance  but the sample style will   also affect the text itself (opacity ) attribute. So changing it back to not transparent value will show  the text lines non transparent - deepening of the setting of the textarea widget rows property
To understand better what I meant here you can use the style textarea2  instead of  textarea1 :
.textarea2 {
 width: 20%;
  height: 150px;
  padding: 12px 20px;
  box-sizing: border-box;
  border: 2px solid #ccc;
  border-radius: 20px;
  font-size: 16px;
  resize: none;
  background: rgba(204, 204, 204, 0.2);
  line-height:30px;
  font-weight:bold;
  opacity:0.7 ;
