Unable to get live sensor data from twx to studio using repeater widget
hemmanth2545
7-Bedrock
Hi, I'm getting Live Values from PLC and able to set in the infotable as attached in the document. but, when i want to view the live sensor values in the repeater widget of vuforia studio it isn't showing.
I have recorded all the steps and attached in the document. Kindly, guide me where i have gone wrong.
Thanks in advance.
here from document you provided i understood one thing.
Service which are called in studio need to be triggered. what you can do is......take button in 2d interface and bind click event of button to service which you want to execute. that will work.
check this solution and do let me know if anything needed.
thanks,
Suraj Patil
