Using Thingmark within an Application We've Designed?
AdamFagan
8-Gravel
Is it possible to use a Thingmark to view a model within a HoloLens application we've written?  If yes, how?  If not, is that type of integration on the roadmap for the Thingworx View?
katte
(To:AdamFagan)
Hi Adam,
ATM, it is not possible to embed within an another HoloLens Application. Can you please provide more details about your use-case? In that way we can have a story for feature enhancement.
Giri
Do you have designed your application in Unity or other game-engine? Then you should take a look at Vuforia. ThingWorx experiences are based on Vuforia. You only have to do more work yourself to get things done, but you have more control about it.
