7-Bedrock
October 4, 2021
Vuforia View App on iOS 15
  • October 4, 2021
  • 2 replies
  • 973 views
Hi All,
I found a problem when upgraded device iOS version to 15.0.
Open Model target project can see model detection tracker.
That project cannot open because it would re-track over and over after scan the equipment.
I tried 3 difference device.
Hi @william_shih ,
I performed a sanity test with the Vuforia View App 9.2.3 on iOS 15.0.0 and the Model Target experience worked as expected.
A quick test from you side, would be to upgrade the Vuforia View app 9.2.3 and test the behaviour out.
If you are still facing the same issue, could you please elaborate on the issue that you have? It is not clear to me what you are experiencing.
Thank you.
Marius
