controlling rotation via slider issue
JL_18346
I created a new experience where the rotation of the model is controlled by a slider.
This worked fine in the past.  It previews okay and works when viewed with an Android-based phone, but doesn't work on an iPad with the latest iOS.
any thoughts?
sebben
(To:JL_18346)
can you explain what you have done to control the rotation?
Just connecting the value property of the slider with a rotation of the model works for me on IOS.
Thanks.
sdidier
(To:sebben)
Hello, We can expect the same behavior in the same Experience between platforms/devices. Here, to investigate more deeply, I will check in log files of Vuforia View, in Android and in iOS. Maybe we can find a verbose who explains this error in iOS log file. Also, a simple project where a such issue is reproducible will be a good start to investigate. It is a good way to avoid any side effect from an error from another JavaScript function in iOS not related with the behavior seen. Best regards, Samuel
