API for Reusable Attributes,Global Enumerations
ZQ_10827176
3-Newcomer
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.1.0
Windchill12: API for create Reusable Attributes and Global Enumerations then link with Type and Parts Link.
Windchill12 如何使用API的方式创建可重用属性、全局枚举,并且应用于类型WTPart上和PartsLink上。
Hi ZQ_10827176,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Best Regards,
Community Moderation Team.
@ZQ_10827176
The following code file has only been tested on windchill 11.0, you can run it on windchill 12.0 for reference
Hello @ZQ_10827176
It looks like you have a response on your topic. If it helped you solve your question please mark the reply as the Accepted Solution.
tarik_p
(To:ZQ_10827176)
Please open one thread per request to get exact help!
Reusable attributes are also called global attributes.
Java APIs differ based on the type of attributes whether they are local, global, etc because the way each type is stored and managed in the db is different.
Almost all APIs are collected in the hub of Persistence Management CS220824.
