Add Creo model parameter values as suffix to published additional files thru xml
Dobrisa
Is there a way to modify the additional files published names by using model parameters (like revision, or version, for example) as a suffix?
What I'd like to do is something like this:
<publish on="create-representation" display-label="Publish w/ additional files" additional-files="dump_to_all" output-suffix=">{revision parameter} </> but as another post noted, the keys aren't available.
Hi @Dobrisa ,
This https://www.ptc.com/en/support/article/CS216668 article should suit your purpose.
Dobrisa
(To:TrueMaverick)
Thanks! We have that the AfterEDRLoader running now and it does in fact name things appropriately.
