Add Name beside Change Object Number in Title
JS_10265661
Currently the title display is "Change Object Type - OBJECTNUMBER, CAGE CODE"
The desired title display is "Change Object Type - OBJECTNUMBER, OBJECTNAME, CAGE CODE"
Windchill PDMLink 12.0.2.5
Similar to how WTDocuments and WTParts display the information in the title, only without the requirement for revision.
I was unable to find any preferences that address this
Hah, I asked the same question slightly differently.... let me know if you figure out anything!
HelesicPetr
(To:JS_10265661)
Hi @JS_10265661
The display identity is managed by service delegate. Each Type has own delegate and is configured in a service.properties in a codeabse
service definition for WTpart
wt.services/svc/default/wt.identity.DisplayIdentification/null/wt.part.WTPart/3=wt.identity.DisplayIdentificationWTPartDelegate/duplicate
extends a wt.identity.DisplayIdentificationWTPartDelegate with own Java class and modify the getDisplayIdentity as you need.
set the preference with own class replace wt.identity.DisplayIdentificationWTPartDelegate to your class "com.ext.MyDisplayWTPDelegate"
OOTB getDisplayIdentity for WTPart
  public DisplayIdentity getDisplayIdentity() {
    DisplayIdentity var1 = this.getFromCache();
    if (var1 != null) {
      return var1;
    } else {
      StandardViewVersionedDisplayIdentity var2 = new StandardViewVersionedDisplayIdentity(this.getResourceBundle(), this.getMessageKey(), this.getDisplayType(), this.getDisplayIdentifier(), this.getConceptIdentity(), this.getVersionIdentity(), this.getIterationIdentity(), this.getIterationIdentitySansView());
      return var2;
described example is for WTPart object.
for WTDocument there is another preference definition and Class
wt.services/svc/default/wt.identity.DisplayIdentification/null/wt.doc.WTDocument/3=wt.identity.DisplayIdentificationWTDocumentDelegate/duplicate
Hope this can help.
PetrH
