edit advancedSearch.wt.workflow.work.WorkItem property in SearchableAttributesByType.properties.xconf to add thePersistInfo.modifyStamp :
run xconfmanager -p and restart :
good luck
Hi @AL_9355918
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
follow the same logic as in https://www.ptc.com/en/support/article/CS180432 , but the workitem
good luck
Thank you so much!
