This widget could not be displayed.
Add last modified date to work item advanced search
AL_9355918
3-Newcomer
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.0
I would like to be able to filter work items by their last modified date - how would I be able to add this as an attribute to an advanced search.
none
Fadel
23-Emerald I
(To:AL_9355918)
edit advancedSearch.wt.workflow.work.WorkItem property in SearchableAttributesByType.properties.xconf to add thePersistInfo.modifyStamp
run xconfmanager -p and restart :
good luck
Fede
Hi @AL_9355918
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Fadel
23-Emerald I
(To:AL_9355918)
follow the same logic as in https://www.ptc.com/en/support/article/CS180432 , but the workitem
Fede
Fadel
23-Emerald I
(To:AL_9355918)
good luck
Fede
AL_9355918
3-Newcomer
(To:Fadel)
Thank you so much!
