Version: Windchill 13.0
Use Case: I am trying to setup an "Advanced Search" against the "Change Notice" object type. However, I have noticed I have no option to add any "Attributes" into the "Criteria" section of my search. Please refer to the attached image.
Description:
I have noticed that I can select other object types which provides the opportunity to add attributes into "Criteria" section of the search. Can anybody suggest why I don't have this option for the "Change Notice" object type?
Hi @Turko,
It works fine on my system.
I just wanted to check whether any attributes are displayed when you click on Add Condition?
Anything in Method Server logs?
Not sure if these are related to the issue but these crept up at a similar time that I tried to select the "Add Condition" button:
2026-01-27 10:54:12,164 ERROR [QueryBuilder Type Pre-Loader] com.ptc.core.lwc.common.view.AttributeDefinitionReadView - Invalid mapping : theChangeable2@wt.change2.RelevantRequestData2~theChangeRequest2^xxx_ChgMgmtReview~state.state for attribute : alias_state ATI : WCTYPE|wt.doc.WTDocument|xxx_DesignChgDoc com.ptc.core.meta.common.impl.LogicalAttributeFormatException: Unable to find logical attribute: "xxx_ChgMgmtReview"
at com.ptc.core.meta.common.impl.LogicalIdentifierFactory._translate(LogicalIdentifierFactory.java:770)
at com.ptc.core.meta.common.impl.LogicalIdentifierFactory._translate(LogicalIdentifierFactory.java:504)
at com.ptc.core.meta.common.impl.LogicalIdentifierFactory.get(LogicalIdentifierFactory.java:300)
at com.ptc.core.meta.common.impl.LogicalIdentifierFactory._translate(LogicalIdentifierFactory.java:576)
at com.ptc.core.meta.common.impl.LogicalIdentifierFactory.get(LogicalIdentifierFactory.java:339)
at com.ptc.core.meta.common.impl.LogicalIdentifierFactory._translate(LogicalIdentifierFactory.java:548)
at com.ptc.core.meta.common.impl.LogicalIdentifierFactory._translate(LogicalIdentifierFactory.java:549)
at com.ptc.core.meta.common.impl.LogicalIdentifierFactory.get(LogicalIdentifierFactory.java:1088)
at com.ptc.core.lwc.common.view.AttributeDefinitionReadView.initAttributeTypeIdentifier(AttributeDefinitionReadView.java:973)
at com.ptc.core.lwc.common.view.AttributeDefinitionReadView.getAttributeTypeIdentifier(AttributeDefinitionReadView.java:858)
at com.ptc.core.lwc.common.view.AttributeDefinitionReadView.getAttributeTypeIdentifier(AttributeDefinitionReadView.java:1952)
at com.ptc.core.lwc.server.cache.ConstraintFactory.getConstraintDefViews(ConstraintFactory.java:224)
at com.ptc.core.lwc.server.cache.ConstraintHelper.translateUnpersistedConstraints(ConstraintHelper.java:696)
at com.ptc.core.lwc.server.cache.ConstraintHelper.translateAttConstraintsToViews(ConstraintHelper.java:652)
at com.ptc.core.lwc.server.cache.AttHelper.translateAttDefsToViews(AttHelper.java:1120)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.translateTypeDefToView(TypeDefinitionManager.java:2874)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.retrieveAndCacheType(TypeDefinitionManager.java:625)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.getTypeDefView(TypeDefinitionManager.java:802)
at com.ptc.core.lwc.server.StandardTypeDefinitionService.getTypeDefView(StandardTypeDefinitionService.java:486)
at com.ptc.core.lwc.server.StandardTypeDefinitionService.getTypeDefView(StandardTypeDefinitionService.java:1056)
at jdk.internal.reflect.GeneratedMethodAccessor222.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at jdk.proxy2/jdk.proxy2.$Proxy37.getTypeDefView(Unknown Source)
at com.ptc.core.lwc.server.LWCLocalizedValuesAugmentor.augment(LWCLocalizedValuesAugmentor.java:176)
at com.ptc.core.meta.descriptor.server.impl.AbstractLocalizedValuesFactory.addToLocalizedValues(AbstractLocalizedValuesFactory.java:678)
at com.ptc.core.meta.descriptor.server.impl.AbstractLocalizedValuesFactory.get(AbstractLocalizedValuesFactory.java:165)
at com.ptc.core.meta.descriptor.common.impl.RetrieveDefinitionDescriptorRemoteWorker.doWork(RetrieveDefinitionDescriptorRemoteWorker.java:62)
at com.ptc.core.command.common.RemoteWorkerHandlerImplementation.handleRemoteWorker(RemoteWorkerHandlerImplementation.java:29)
at com.ptc.core.meta.common.RemoteWorkerHandler.handleRemoteWorker(RemoteWorkerHandler.java:38)
at com.ptc.core.meta.descriptor.common.impl.DefaultDescriptorFactory.get(DefaultDescriptorFactory.java:184)
at com.ptc.core.meta.descriptor.common.impl.DefaultDescriptorFactory.get(DefaultDescriptorFactory.java:225)
at com.ptc.core.query.report.command.server.ReportTypeModelCommandDelegate.doExecution(ReportTypeModelCommandDelegate.java:155)
at com.ptc.core.command.common.delegate.AbstractCommandDelegate.execute(AbstractCommandDelegate.java:216)
at com.ptc.core.command.common.CommandDelegateForwarder._remoteExecute(CommandDelegateForwarder.java:284)
at com.ptc.core.command.common.CommandDelegateForwarder.remoteExecute(CommandDelegateForwarder.java:232)
at com.ptc.core.command.common.CommandDelegateForwarder.execute(CommandDelegateForwarder.java:194)
at com.ptc.core.command.common.bean.AbstractServerCommand.execute(AbstractServerCommand.java:202)
at com.ptc.core.query.report.common.impl.TypeDisplayInfo.buildTypes(TypeDisplayInfo.java:159)
at com.ptc.core.query.report.common.impl.TypeDisplayInfo.<init>(TypeDisplayInfo.java:109)
at com.ptc.core.query.report.common.impl.TypeDisplayInfo.<init>(TypeDisplayInfo.java:115)
at com.ptc.core.query.report.common.impl.TypeDisplayInfo.getTypes(TypeDisplayInfo.java:76)
at com.ptc.windchill.enterprise.queryBuilder.StandardQueryBuilderService$TypePreLoader.run(StandardQueryBuilderService.java:173)
at java.base/java.lang.Thread.run(Thread.java:833)
2026-01-27 10:56:18,267 ERROR [wt.intersvrcom.SiteMonitor.timer] wt.intersvrcom.SiteMonitor - Names=[xxxxxx], URL=xxxWindchill/servlet/WindchillGW, Status=SERVLET ENGINE NOT RESPONDING, ResponseSeconds=0.965, TimeOfPing=2026-01-27 10:56:16.401 +0000
Hi @Turko,
There appears to be an invalid alias attribute mapping.
Please refer to the following article to resolve this issue.
https://www.ptc.com/en/support/article/CS429528?source=search
Thanks @TDT but I don't think this is likely to explain why I have no attributes available to add to my criteria for an "Advanced Search" and cannot activate the "Add Condition" functionality. Would you agree?
Ok, Have you tried addressing the Alias Mapping issue to see if it resolves the problem?
I have not yet no. This is what I was referring to in my last post. I wasn't sure if it was related to the issue. However, if you fell it could be, I will prioritize looking into this.
Hi @Turko,
I was able to reproduce the issue to some extent.
I encountered the same error on my system.
