By Pass revise transition Or Set Object Revision to specific Revision
JM_10276355
Is anyone aware of  below cases,
  • API to by pass the revise transition of the object to set new version
OR
  • API to set version to specific version without revising to new revision of the object.
Please let me know if anyone aware of this cases or any alternative if you feel.
Thanks in Advance
You can see the APIs behind ChangeRevisionLabelUtility, internally they are using the below API, but they are doing a bunch of validation before, so if you can directly use ChangeRevisionLabelUtility that would be great, details are explained on this help center page: Changing the Revision of Objects (ptc.com)
VersionControlHelper.service.changeRevision(paramArrayList.get(0), newRevision, true);
