Conditional Execution of Automatic Promotion Requests and Assignment of 'Created By' Role"
Emrec@n
8-Gravel
Version: Windchill 12.0
In Windchill, I am creating an automatic promotion request at the end of the change review process with the following code. However, I have two questions that I couldn't resolve.
  1. Question: I have defined a boolean variable "Should automatic promotion request be initiated?" within the activity at the approval stage for the automatic promotion request code. I want the code below to execute if this variable is true; otherwise, it should not execute. How can I achieve this?
  2. Question: I want the person in the submitter role who initiated the change review process to be assigned as the "created by" for the promotion request. These questions might be simple, but I haven't been able to find a solution.
"Code to Automatically Create Promotion Requests for Documents in Change Review"
wt.pom.Transaction trx = new wt.pom.Transaction();
wt.change2.WTChangeReview changeReview = (wt.change2.WTChangeReview) primaryBusinessObject;
// ChangeReview nesnesinden kapsayıcıyı alıyoruz
wt.inf.container.WTContainer container = changeReview.getContainer();
wt.inf.container.WTContainerRef containerRef = wt.inf.container.WTContainerRef.newWTContainerRef(container);
// ChangeReview nesnesinden etkilenen dokümanları alıyoruz
wt.fc.QueryResult queryResult = wt.change2.ChangeHelper2.service.getChangeables(changeReview);
wt.fc.collections.WTSet set = new wt.fc.collections.WTHashSet();
while (queryResult.hasMoreElements()) {
wt.doc.WTDocument document = (wt.doc.WTDocument) queryResult.nextElement();
set.add(document); // WTDocument nesnelerini koleksiyona ekliyoruz
try {
trx.start();
wt.maturity.MaturityBaseline maturityBaseline = wt.maturity.MaturityBaseline.newMaturityBaseline();
maturityBaseline.setContainerReference(containerRef);
maturityBaseline = (wt.maturity.MaturityBaseline) wt.fc.PersistenceHelper.manager.save(maturityBaseline);
wt.maturity.PromotionNotice pn = wt.maturity.PromotionNotice.newPromotionNotice("Custom_Promotion_Request");
pn.setTypeDefinitionReference(wt.type.TypedUtilityServiceHelper.service.getTypeDefinitionReference("tr.com.aselsan.hbtwinctest02.HBT.PromotionNoticeTest"));
pn.setPromotionDate(new java.sql.Timestamp(System.currentTimeMillis()));
pn.setContainer(container);
pn.setContainerReference(containerRef);
pn.setMaturityState(wt.lifecycle.State.toState("RELEASED"));
pn.setDescription("theDescription");
pn.setConfiguration(maturityBaseline);
// Assign iteration creator with submitterRef before saving Promotion Notice
// wt.vc.VersionControlHelper.assignIterationCreator((wt.vc.Versioned) pn, submitterRef);
wt.vc.baseline.BaselineHelper.service.addToBaseline(set, pn.getConfiguration());
pn = wt.maturity.MaturityHelper.service.savePromotionNotice(pn);
wt.maturity.MaturityHelper.service.savePromotionTargets(pn, set);
trx.commit();
trx = null;
} catch (Exception e) {
if (trx != null) {
trx.rollback();
e.printStackTrace(); // Hata durumunu işleyin veya kaydedin
"The assignment code I used when creating a different object before, but this code did not work (perhaps I used it incorrectly)."
@HelesicPetr, I believe you can help with this. I would really appreciate your assistance. Have a great day.
HelesicPetr
(To:Emrec@n)
Emrec@n
For the creator, I would try to use setPrincipal with the name of user that should be used
usually you get session principal store it as a original user variable
then change the session to user who should save the object
save the object
set the session user back to original user.
// get the session user
wt.session.SessionHelper.manager.getPrincipal();
// set the session user
wt.session.SessionHelper.manager.setPrincipal("userName");
 PetrH
5 REPLIES 5
HelesicPetr
(To:Emrec@n)
Hi Emrec@n
1. You can use the variable in the condition and based on that value go to a right way in the workflow path
usually copy the variable from user task to global variable in the workflow. it is ootb function.
2. I guess that the method assignIterationCreator can not be used to the object that is not versioned. Promotion Request does not have revisions and iterations..
PetrH
@HelesicPetr
Thank you very much for your guidance. How can I copy the selected value within the Activity to a global variable? Do you have a ready method for this? Finally, what method can I use to assign the user to the promotion notice? Do you have any suggestions?🙏🙏🙏
HelesicPetr
(To:Emrec@n)
Hi Emrec@n
It is OOTB function in the workflow, that does not need any coding.
PetrH
HelesicPetr
(To:Emrec@n)
Emrec@n
save the object
 PetrH
@HelesicPetr  Great, both of my issues have been resolved. Thank you very much for your guidance. I was very close to the solution, but your direction helped me reach the result. You are the best Windchill expert I have encountered.
I am sharing the complete code below for those who need it.
wt.org.WTPrincipal originalUser = wt.session.SessionHelper.manager.getPrincipal();
wt.team.Team team = wt.team.TeamHelper.service.getTeam(changeReview);
java.util.HashMap map = wt.team.TeamHelper.service.findAllParticipantsByRole(team);
    set.add(document);
try {
    trx.start();
    // Belirli bir kullanıcıyı "SUBMITTER" rolü olarak ayarlama
    String submitterUserName = null;
    for (Object key : map.keySet()) {
        wt.project.Role role = (wt.project.Role) key;
        if (role.toString().equals("SUBMITTER")) {
            java.util.List participants = (java.util.List) map.get(key);
            if (!participants.isEmpty()) {
                wt.org.WTPrincipalReference participantRef = (wt.org.WTPrincipalReference) participants.get(0);
                wt.org.WTPrincipal participant = participantRef.getPrincipal();
                submitterUserName = participant.getName();
                break;
    if (submitterUserName != null) {
        // Set the session user to the submitter
        wt.session.SessionHelper.manager.setPrincipal(submitterUserName);
    } else {
        throw new Exception("Submitter role not found.");
    trx.commit();
    trx = null;
    if (trx != null) {
        trx.rollback();
} finally {
    // Restore the original user
    wt.session.SessionHelper.manager.setPrincipal(originalUser.getName());
