Could not have the Wizard(s) display banner and close upon successfully calling the processor class
SriTalatam
Implementing a custom wizard in Windchill that will eventually create a WTPart and establish some associations. The process involves a multi-step wizard defined in custom-actions.xml and managed by a final form processor.
FormResult Message:
<script>
top.PTC.getMainWindow().PTC.messaging.showInlineMessage
([{"MessageTitle":"CONFIRMATION:",
"Messages":["Repair Kit generated successfully with number: C1000"],"MessageType":"SUCCESS"}]);
top.PTC.getMainWindow().PTC.performance.stopComponentTimer('WizardSubmit');
top.handleSubmitResult(0, 1, ' ', '\x20', {"extraData":{}})
</script>
While the expectation is to show a banner message or just close the windows, it just goes back to a refreshed parent wizard.
Console Error:
Uncaught TypeError: Cannot read properties of undefined (reading 'getMainWindow')
Approaches Tried:
Various things have been tried including sending the feedbackmessage explicitly, redirecting to the URL manually. PFA for detailed explanation. Any feedback is appreciated. Thank you!
SriTalatam
(To:Imad_A)
It is the JSP location. Moving all the pages to the netmarkets folder resolved the issue.
As quoted in the customization guide:
"Windchill will expect all jsp pages related to this object type to be located in \codebase\netmarkets\jsp\"
Thank you @Imad_A for the support.
6 REPLIES 6
Imad_A
(To:SriTalatam)
I implemented a similar solution by overriding setResultNextAction in the FormProcessor.
You can adapt the snippet below to your own context. Hope this helps.
@Override
public FormResult setResultNextAction(FormResult result, NmCommandBean clientData, List<ObjectBean> objects)
throws WTException {
FormResult retval = super.setResultNextAction(result, clientData, objects);
String js = "top.opener.reloadTable(top.opener.PTC.jca.table.Utils.getTable(\"adhocTable\"));window.close();";
retval.setJavascript(js);
retval.setNextAction(FormResultAction.JAVASCRIPT);
return retval;
iaarab
SriTalatam
(To:Imad_A)
Thank you for the response.
I tried this in the processor class along with the doOperation() and issue persists.
Whenever the 'result' is being handled, it just fails to decipher the response, esp 'top.PTC.getMainWindow()'
Imad_A
(To:SriTalatam)
It works fine on my side by overriding setResultNextAction() and returning a FormResultAction.JAVAscript &colon;
@Override
String js = "top.PTC.getMainWindow().PTC.messaging.showInlineMessage ([{\"MessageTitle\":\"CONFIRMATION:\","+
"\"Messages\":[\"Repair Kit generated successfully with number: C1000\"],\"MessageType\":\"SUCCESS\"}]);"+
"top.PTC.getMainWindow().PTC.performance.stopComponentTimer('WizardSubmit');"+
"top.handleSubmitResult(0, 1, ' ', '\\x20', {\"extraData\":{}})";
return retval;
SriTalatam
(To:Imad_A)
May i know if you tried this with multi step wizard?
I just used the above code (looks you took the <script> piece from the result response? ) you shared and still the same old behavior. Additionally, are you on WC 13.0 ?
Imad_A
(To:SriTalatam)
Yes, I tested this with a multi-step wizard as well.
Regarding the version, I’m currently working on WC 12.1, not 13.0.
SriTalatam
(To:Imad_A)
