Create Variant Specification by API
Lukasz1
11-Garnet
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.2.23
I would like to programmatically create Variant Specification. As far as I can see in the documentation such customization should be possible.
e.g.
Sample Code for VariantLoadNavCriteriaBean API but the problem is I cannot find
VariantSpecLoaderHelper.service.loadVariantSpecs(beans, partConfigSpecBeans, atoConfigSpecBeans);
The classes for 'VariantSpecLoaderHelper' are not present in the Windchill installation and I do have license and I am able to manually create Variant Specification in the system.
Can you help me to resolve this issue?
HelesicPetr
(To:Lukasz1)
Hi @Lukasz1
You have to add the library from the Windchill installation to your IDE
here is example of my configuration in inteliJIdea
PS:: I don't have Windchill installation on my IDE client. I have just a copy of the needed libraries from the Windchill structure of the correct version.
PetrH
7 REPLIES 7
Fadel
23-Emerald I
(To:Lukasz1)
What do you mean by  'VariantSpecLoaderHelper' are not present in the Windchill installation .
What error are you getting
Fede
Lukasz1
11-Garnet
(To:Fadel)
I've seen the Loading Loading Variant Specifications Using an API , but I cannot find the corresponding helper method which is used in the snipped.
 Can you help me find it?
Fadel
23-Emerald I
(To:Lukasz1)
can you take a look at https://www.ptc.com/en/support/article/CS273636
Fede
Lukasz1
11-Garnet
(To:Fadel)
It is exactly what I need, but I am missing the library (.jar) where the class (VariantSpecLoaderHelper) can be found.
Can you help me to find it?
Fadel
23-Emerald I
(To:Lukasz1)
Hi ,
see below
Fede
HelesicPetr
(To:Lukasz1)
Hi @Lukasz1
PetrH
TomU
(To:Lukasz1)
