How to Fully Register and Verify a Servlet in Windchill?
YS_10608297
7-Bedrock
Version: Windchill 12.1
Use Case: Ensure that all WTDocuments associated with a given WTPart have secondary content. If any documents lack secondary content, display a warning popup to the user. If the user proceeds, allow downloading of available secondary content as a ZIP file.
Description:
In Windchill, WTDocuments can have secondary content such as PDFs or additional attachments. However, not all documents necessarily contain secondary content. When a user selects a WTPart, the associated WTDocuments should be checked for missing secondary content before proceeding with further actions, such as downloading the documents.
Hi @YS_10608297
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
HelesicPetr
(To:YS_10608297)
Hi @YS_10608297
You should describe your use case. What does the user do ? Select WTPart? and what next?
What does the select mean? to put the wtpart to a structure? or you have some utility to download a content from the WTDocumnet based on WTPart selection?
Or do you describe a creating connection between the WTPart and WTDocumnet?
I do not understand your situation and what you really want.
You should describe what the system has to do more descriptive that others can understand your thoughts .
PetrH
Agree with @HelesicPetr. Title of post and write do not align. It reads like a copy/paste of requirement of something you are being asked to develop. It lacks context.
