Email notifications body is empty on workflows
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
- Labels:
General Customization
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I had few variables, which were set to visible on an activity, and not visible on the other one. That caused a null value, which in-turn wiped out the entire 'body' of the html/email.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Are using a notify by email robot ?
like below
- Chapters
- descriptions off, selected
- captions settings, opens captions settings dialog
- captions off, selected
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
No, I am using the 'Send Notification' checkbox in activity.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @RG_10753677
It seams that email is checked by some software and adds the bottom description ... "The information transmitied by"....
I would say that the sw riped out the body for security reason.
If Iam right you need to contact your IT to solve the issue.
PetrH
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
what @HelesicPetr says makes totally sense,if you want to inevtigate from the windchill side anyway
you may enable below logger to TRACE,steps in attached video
wt.mail.EMailMessage
you should then then see the body sent by windchill in the logs :
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
It is not happening for all emails. Some emails are working fine, some don't.
the logs for the email that works, you can see the html
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Content-Transfer-Encoding: quoted-printable
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <html>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <!-- bcwti
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - --
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - -- Copyright (c) 1997, 1998 Windchill Technology, Inc. All Rights Reserv=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ed.
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - -- This software is the confidential and proprietary information of
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - -- Windchill Technology. You shall not disclose such confidential inform=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ation
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - -- and shall use it only in accordance with the terms of the license
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - -- agreement you entered into with Windchill Technology.
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - -- ecwti
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - -->
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <!-- ECR-00220
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - RG Test CR 9.28.1
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - =20
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <head>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <STYLE TYPE=3D"text/css">
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - B,P,FONT,H1,H2 {font-family:Arial, Helvetica, Geneva, Swiss, SunSans-Regula=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - r quotes=3Dnone</SCRIPT> }
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ..tableTabNSel { background-color: #DDDDDD; font-style: arial, he=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - lvetica; font-size: .9em; font-weight: bold;}
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ..tableRowSel { background-color: #EEEEEE; font-style: arial, he=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - lvetica; font-size: .9em;}
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ..tableWfHeader { background-color: #EEEEEE; font-style: arial, he=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - lvetica; font-size: .9em; }
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ..propTitle { font-size: 1em; font-weight: bold; color: #00000=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - 0;}
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ..objectTitle { font-size: 1em; font-family: sans-serif;}
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ..propValue { font-size: 1em; color: #000000; }
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - </STYLE>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - </head>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <body>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <font face=3D"Arial, Helvetica, sans-serif">
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - You have been assigned a <A HREF=3D"https://windchill-dev.xyz.com/Windc=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - hill/app/#ptc1/tcomp/infoPage?oid=3DOR%3Awt.workflow.work.WorkItem%3A164472=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - 15&u8=3D1">Task: Component Verification </A>.
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - </font>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <table border=3D"0" cellpadding=3D"3" cellspacing=3D"0">
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <tr><td align=3D"right" valign=3D"top" nowrap >
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - </td><tr>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <tr><td align=3D"right" valign=3D"top" nowrap class=3D"propTitle">
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Instructions:
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <td colspan=3D"4" align=3D"left" valign=3D"top" class=3D"propValue">
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ECR Number: ECR-00220
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <br/>ECR Description: RG Test CR 9.28.1
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <br/>Things to do:
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <br/> a. Please review the ECR.
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <br/> b. Reassign to the appropriate owner, if required.
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <br/> c. Perform component verification activity.
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <br/> d. Attach results of component verification activity to the ECR=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <br/> e. Select passed or failed based on the results.
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <br/> f. If component verification is not needed for this ECR, please=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - select =E2=80=98Not Applicable=E2=80=99 and also provide the reason in com=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ments section.
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Process Initiator:
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <td align=3D"left" valign=3D"top" class=3D"propValue">
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Rachana Gurram
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <td align=3D"right" valign=3D"top" nowrap class=3D"propTitle">
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Priority:
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Highest
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - </td></tr>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Assignee:
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Due Date:
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Role:
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Software Engineer
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Process:
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <A href=3D"https://windchill-dev.xyz.com/Windchill/ptc1/process/info?oi=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - d=3DOR%3Awt.workflow.engine.WfProcess%3A16446970&u8=3D1">xyz Engine=
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - ering Change Request_ECR-00220</A>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - <BR>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - </table>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - </body>
2023-09-28 11:10:49,467 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - </html>
2023-09-28 11:10:49,545 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - 250 2.0.0 OK <64658578.588.1695917449452@hyleslzwndchdev.xyz.LOCAL> [Hostname=1234567.namprd19.prod.outlook.com]
2023-09-28 11:10:49,545 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - DEBUG SMTP: message successfully delivered to mail server
2023-09-28 11:10:49,545 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - QUIT
whereas, for the email that the body was empty, you can see in the logs there is no html.
2023-09-28 11:11:03,222 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - Content-Transfer-Encoding: 7bit
2023-09-28 11:11:03,222 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - .
2023-09-28 11:11:03,300 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - 250 2.0.0 OK <796252988.589.1695917463222@hyleslzwndchdev.xyz.LOCAL> [Hostname=123456789.namprd19.prod.outlook.com]
2023-09-28 11:11:03,300 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - DEBUG SMTP: message successfully delivered to mail server
2023-09-28 11:11:03,300 INFO [EMailQueue.SchedulingThread] wt.system.out wcadmin - QUIT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
would you let me know about your windchill version
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
